Re: Choice of gear oil
[size=+1] Run and hide!!! It's another oil thread.... [/size]....
Ok, got that out of the way...
Do a search... You'll find THOUSANDS of threads on exactly this question...
You will also find the answer is almost always... "I use___________ (insert name of favourite oil)...."
Simplest and easiest thing to do is go by the book.... For drives, use Quicksilver High Performance Gear Lube.... Yes it's expensive, but so is the drive it's protecting!
Chris.........
