Re: Choke and mixture adjustment.
Mixture = best idle quality.
Choke: 1) Stone cold engine. 2) Remove flame arrester
3) Open throttle about 1/4. 4) Did choke plate close? If not its either misadjusted or broken. 5) Loosen choke plate screws. 6) If choke is closed, rotate disc so choke plate opens slightly. The turn the opposite direction until it just closes. If choke is open, turn disc until choke just closes. If choke does not respond to disc movement, remove the disc and see what's missing. Repair as needed. Readjust.
Finally, start engine. Choke should open slightly at engine start. If not, the pull-off needs attention/replacement. As engine warms choke coil will continue to pull choke open. If not, it needs repair. You also should have a service manual as all this is explained in more detail with pictures.
