The float in my 9.9, 4 stroke 323 cc Mercury carburator was leaking so I took it home and cleaned it and reinstalled it. Although the engine starts and it no longer leaks, when I push the choke in after it has warmed up, the engine stalls. I adjusted the carb so it would open and close all the way, but it obviously cannot reach max speed since I cannot push the choke back in.
I adjusted the accelerator by feel since I don't have a tachometer, but I don't believe my issue is the accelerator, or idle speed. I adjusted the WOT Wide Open Throttle stopper to specs which is less than 1 mm. Nothing is sticking from what I could tell.
Anyone experience similar issues, know a fix or have any suggestions?
I did not rehaul the carburator, just cleaned it.
Your help is appreciated.
Thank you
Bernard
Thank you
Bernard
