phiber_optikx
- Jun 22, 2013
- 25
Sorry if some of this sounds stupid. I am not at all mechanically inclined. So today we decided to water test my new boat. Prior to this we had started the engine two times with the muffs and it ran fine. Since then the only thing I have done is an oil change. So we get to the lake, and the engine turns but wont fire. Try for several minutes and can't get it to go. We pull the spark plugs and they are still good. I had changed them immediately after buying the boat. We decided we weren't getting on the water today and dragged it back home to work on it with the muffs on. After dropping some fuel behind the plugs it starts but dies after a few seconds. BUT now it starts with the choke held. About 3 seconds after releasing the choke it dies. We started it about 50 times with the choke held and even if you run it for 5 minutes it still dies after release. We adjusted the manual choke every way possible but simply can't get it to idle. Any suggestions? Fuel filter is clean btw.
