Choke Issues 1989 350 with Roch 4bbl
CRay45DB
On my 89 Merc, I have 1 issue that has led to another annoying issue.
The first problem is the clip, Merc part number 89668, clip for the choke rod keeps coming disconnected, leaving me with no choke. So messing around with this, I suddenly discovers I was holding the choke rod in my hand, disconnected from the choke thermostat assembly. I stuck the rod back down and saw the place where the choke rod is supposed to go through this, but was there tension on this that got unraveled when it got disconnected?
So, how do I fix, if needed to be fix the thermostat, and any ideas on how to keep the rod from coming off the clip.
It's the little things that drive ya crazy!
alldodge
Re: Choke Issues 1989 350 with Roch 4bbl
Whitout any engine serial number I came up with the following: Merc part number 89668 is a chock clevis clip
http://www.**********/parts/detail/merc/M-89668.html
and cost 2.25 each. You didn't unspring anything, the chock opens up by gravety after it warms up and the chock spring expands. Just replace the clevis clip because it sounds like yours is bent or something.
CRay45DB
Serial # 0c521959
Shows the Clovis clip part number obsolete.
So just put it back in the hole and call it a day?
Bt Doctur
do you mean the clip above the pliers?
Bt Doctur
Alldodge, what to replace the *`s with?
NHGuy
Those are available. If you can't find one call Cliff Ruggles at Cliff's High Performance 740 397 2921.
