Imarudedude
- Jul 30, 2008
- 21
Hello all. I have a 1993 90 hp Mercury outboard (serial # 0d179573) that is having some issues.
Im not entirely sure how to use the cold start/choke function with key and if that is indeed my problem or not.
The only way to get the engine to start is to put it in gear and give it a decent amount of throttle. This is obviously not ideal and I don’t intend to drive it until the issue is fixed.
It it has an electric choke/primer (I’m assuming primer not entirely sure) that you can hear click when you press the key in.
Ive heard varying takes on how it should be operated:
Press and hold for five seconds.
Press once prior to starting then depress and turn key.
Press it and hold in when turning over.
Ive tried all of these methods to no avail.
I appreciate any advice or insight anyone could offer this community has always been great!
