Choke selenoid
Squirt
On my '91 Force 90, 2-stroke, Inboard,3 cylinder Bayliner motor,I was having a problem with the choke selenoid not working all the time.I took out the "plunger" and cleaned up all the nasties and it seems to be working every time I ask it to, this is good.My question is,When the wire is disconnected from the selenoid there is 12.2 VDC on the wire when energize,,When the wire is then hooked up,there is only 6.8VDC when energized.Is it normal to have this much voltage drop?Thank,Squirt
petryshyn
Re: Choke selenoid
as said before....no its not normal. Check the switch, wiring, connections and grounds.... :)
