Halstead666
- Jul 23, 2014
- 19
Hello, New guy here......I have a 1996 v-8 5.7 mercrusier that starts a bit rough. i recently rebuilt the carb (2brl) following Mike's carb rebuilt instructions to a tee and have the mixture screw set at 1.25 turns and idle screw at 2.5 screws. When cold Choke plate open from running the previous day but closed completely just prior to start up, following start up procedures I pump throttle in neutral fully once and leave it 1/4 open, when doing this the choke plate is kicked up a bit as per instructions although it then closes completely. I usually have to pump a couple of more times before I can get it to turn over and it runs very rich as I just dumped more gas than needed to get it started. It runs rough as The choke plate opens up as engine warms up over the next few minutes and the black smoke it cleared. It seems that the choke plate should remain open on the initial bump with the throttle.......currently the choke setting is at 2 to the right more lean setting..........I am wondering if I should set it so the plate opens and stays open slightly during start up which is quite a further setting then the 2 to the right?
