Chris Craft 5.7 Volvo Penta Fuel Injected flooding during start up.
Brent0812
5.7 gi fuel injected. When the key is turned to cycle the fuel pumps it pushes gas in one side of the throttle body through a small metal line then stops after it puts a good bit of fuel. Then I turn the key to crank the boat and get even more fuel out of the same metal line and floods out the engine. I just replaced both low and high pressure pumps along with the relay.
Help
ChrisinPHX
You did not give a ton of info about your boat, but if it has this fuel reservoir, it's probably the culprit.
