Chrylser 15 hp hard cold start, poor idle and stalls
Playtime01
1982 Chrysler 15 hp. Have to prime carb with starting fluid to start cold. Idle, revs normally and clunks every three seconds. Stalls while idling. Runs at medium and high speed great. Any idea's?
Whoopbass
Re: Chrylser 15 hp hard cold start, poor idle and stalls
Pull the carb off and clean it. Soak it overnight in a solvent then spray it with carb cleaner and then blow it out with compressed air.
Set the lean/mixture screw about 1 turn out and fire it up. If its revving to high turn the screw out a bit. Idles rough turn it in.
Make sure the choke flap is sealing tight when you cold start it. If the flap has factory holes in them seal them with epoxy (if the carb cleaning doesn't help) and that should make cold starts easier.
Might as well buy some new plugs.
butler1850
Sounds like my '81 motor. If you've got a manual (I'd highly recommend one) the job is fairly easy, even for someone with little to no mechanical skills (like me, but I'm learning fast!).
I ended up doing a complete carb rebuild, and a timing adjustment.
The carb rebuild is fairly straight forward. Remove, clean well with carb cleaner, replace the needle & seat, reassemble. This fixed the hard starts. I suspect the jets, both idle and main, were clogged, at least a little.
To fix the poor idle/stalls/misses, I had to advance the timing a bit by screwing in the "stop" screw on the throttle connection to prevent it from retarding too much. You balance it out so that the throttle is "full closed" at the bottom end the throttle, but still runs smooth. Basically, as the throttle closes, the timing wheel (which controls the throttle lever cam on the carb) turns clockwise. You want to make it turn a "little less far" when you reach low idle... you may need to adjust the throttle linkage a little to get the throttle to the right spot.
Then set your idle mixture. Turn in the idle screw fully, then turn it out 1.5 turns. Start the engine, and adjust upwards until the engine runs rough (slow movements), then downwards utill the same happens. Set the adjustment 1/2 way between the extremes.
javsam
Also a great response by PNWBOAT under the thread "15 hp loading up at idle".there are one way check valves and screens that route excess fuel back to intake.If they get plugged it can cause poor idle.I took a look at mine and sure enough they too had plugged screens.
Playtime01
Cleaned out fuel pump inlet screen that was 1/2 plugged with old black pieces of gas line. Replaced gas lines. Cleaned and rebuilt carb. Set carb and idle speed adjustments. Motor is starting better and not stalling. Thanks for all the help.
