Where do i start motor will not engage into drive forward or reverse. before this problem started there was some grinding noise from motor when engaging.Can anyone help need to take family skiing
The first step I would take is to drain the lower unit lube and see if any chunks/shavings come out. That should give you an idea of what's happened down there.
