Re: chrysler 12.9
this will be the two holes in the rear of the leg .....if you dont see water comming out then dismantle the water pump ASAP and check for water flow through the head with a hose on the engine inlet pipe ( whilst you have the pump off ) these motors do not work well with muffs ..upi need it in a barrel and the water 4 in above the anti ventilation plate.
