banshee130mk2
- Jun 8, 2014
- 38
Hey guys alright ive exhausted myself short of tearing into the lower unit to see if something is dragging. My 130 (prop 13x21) on my 14.5 ft banshee wont rev past 4400. I have checked the tach.. its correct and at 4400 it does 43 mph so the math with slip works. The motors av plate was level with the bottom of the transom. I raised it an inch and there was no change. I have rebuilt the pump and I have pulled the carbs apart and cleaned them. It takes a bit to start cold but once its warm it will fire instantly. Ive pulled the plugs at idle one at a time and the rpm dropped for all cylinders. Ive checked spark. Every cylinder has spark seems weaker than a car spark but its still there... the engine has the coversion on the ignition so it has no cd box.. its running an automotive oil filled coil with a built in resistor. The engine leg is a 1.76 :1 ratio the boat is max weight rated for 1650lbs. Spark plugs are ngk b8hs . Tried a l82 champion and cylinder 2 filled the plug with combustion particles fuzing the bridge to the electrode. Changed back to new b8hs and it runs good. I am wondering if somethin in the lower could be causing it to be a bit low on rpm . Maybe the coil is going and cuts a cylinder at high rpm. Could reeds cause this? Help!!
