CHRYSLER 140 IGNITION (:
elliotlake
OK I must go back on the hwy for a month...
I will be reading here often.
z**
Had engine running last week 10 minutes.
No start last try.
Had spark on one plug yesterday...now none.
No fuse, rather circuit breaker (continuity 0 with ohm test).
Key on yellow shows 0 -- it should --jump switch cranks her. (It will crank with key BTW I want to be beside to check spark with DIY tester).
Its all new but I have been reading archives TX!
When I get home I will try CD tests and coil tests.
This note is mainly to remember what I have done. dont want to waste your time.
I am DETERMINED to learn and GET BACK ON WATER ---its been too many years :)
Without you guys it would be Mission Impossible.
One BIG question for now...Anyone reading this have you switched to AUTO ignition?
(Difficult &/or expensive).
Dave
Lake Huron, Ontario
