kbh121956
- Jun 30, 2013
- 486
Hello Group, I picked up a 35 HP with controls and wiring that had been sitting in a shed for many years. What I have done, I pulled the plugs and fogged the engine. I dropped the lower and inspected the water pump. I was surprised to find that the impeller, plate and pump housing looked brand new! I pressure and vacuumed tested the lower and she held. I replaced the fuel pump diaphragm, the old one was hard and also had a very small pin hole. Replaced the fuel lines with new. Ordered the proper carb kit and rebuilt the carb, I also installed a inline fuel filter after the fuel pump before the carb. I pulled the flywheel, cleaned the points, and checked the gap. The gap was set at .015, the service manual for this engine states the same. I then set the outboard in the barrel, hooked up the gas, turned the key and it started right up. It stayed running. I hooked up a timing light to number 1 spark plug assuming number 1 is the top cylinder and I got nothing! I then hooked the timing light up to number 2 and it was firing. I then pulled the top spark plug wire off and no change. I did notice that the top spark plug wire and been taped up with electrical tape, it looked as if it had rubbed the insulation off at one point. My question is, Is the coil for number 1 bad? The replacement coil runs around 130 dollars each! Compression on both cylinders are 100 psi, The service manual states 95-105. Thanks.
