I've got the water pump out of the motor (it's a '69) and the rubber bushing that goes between the pump housing and the water pipe is in pretty sad shape - see photo. What's this part called and is it available? Also, the impeller face surface in the housing is pitted. I guess I expected it to be fairly smooth. Is pitting normal or should I get a new housing.
Thanks, Jim
Thanks, Jim
