Hello
I'm new here and I'm looking for some help for my Problem. I have a 1979 Chrysler 45HP (457H9K) with no power to the white wire on the top coil. I checked the condenser and breaker points and I also swapped them out to see if the problem moves to the other coil, but it doesn't.
So when I rotate the crank by hand the brown wire on the bottom coil Turns on and off but not the white wire on the top coil.
The engine was running fine last summer and the first time out this summer but then all the sudden this problem showed up.
Anyone any idea?
Any help is appreciated.
Thanks much
Anyone any idea?
Thanks much
