I just changed my impeller for the first time, and took it out for a run last Sat. The water was flowing more than I'd ever seen it flow, so I was happy (although there was a bit of a new whining sound, I just assumed it was the new impeller - my first). The motor was not up to par, and seemed to be missing alot. I wasn't sure if I had a spark issue, but was hoping it was just fuel.
After fresh fuel and a tub of water in the backyard, everything seemed back on target, but there was no water coming out the exhaust this time, and the motor seemed hotter than normal.
I took it on the water tonight, and it didn't go far until it smoked, shut off. Again, no water pumping. I got it back and wanted to see if my impeller was in good shape and sure enough, there was hardly any impeller to find. Most of the blades were totally gone, and what was left was practically melted to the shaft. The key (I think you called it, small pin that sticks out of the shaft and into the impeller) is now bent. Now what???
Is it possible that I installed the impeller upside down, and bent the key while tightening the pump back down on to the L/U? I'm at a loss, it all seemed to be a smooth and relatively simple operation for my first impeller change.
