Chrysler 45 outboard questions (swapping bottom ends)
Bradler
I currently have a 45hp outboard that ended up loosing a tooth on the Dog gear? And I was wondering if a 35hp bottom end would fit/ pump enough water for the 45?
Nordin
Bradler if the 35Hp is earlier then 1976 it will fit right on.
Chrysler manufactured a 35, 45 and 55Hp engine family from mid 60.s until 1975-76.
The different was block displacement and ignition/electric start system.
The LU was the same for all of them with the same gear ratio.
In 1976 there was a "new" 35Hp which was developed from the 25, 30Hp family and in 1977 a "new" 55Hp twin carb engine developed from the 60Hp twin carb intruduced in 1974.
This LU.s will not fit.
Soo you can look for a LU from a 35, 45 or 55Hp Chrysler from 1966 up until 1975 (35 and 55Hp. The 45Hp was the same until Chrysler was out of the OB business in 1984).
LU from a 50Hp Force will also fit.
Bradler
I think I found a 35hp that’s in that year range, just gotta go get it and bolt it on. Thanks for the help!
jerryjerry05
You take it apart?
Sometimes the dog can be ground down to be used again.
Post a pic?
Bradler
I do have it apart, but the dog chipped a tooth petty good, 3/4 of the one tooth is completely gone
