Chrysler 55 hp won't run only backfires
Criv69
Bought this motor for next to nothing and figured it was worth the time to tinker with. Now I'm not sure. Wasn't getting spark after a sheared key but after replacing the key and the ignition system I'm now getting nothing but backfires and smoke. Cranks for two or three seconds, backfires, then I let off the starter. Further attempts to crank yield smoke and another backfire or two. Any adjustments in timing don't make much of a difference.
jerryjerry05
Sounds like the flywheel key has sheared? Again??
Never touch the timing as ​it never moves by itself.
Got the plug wires crossed?
