CHRYSLER 55HP WILL NOT START .
fayaz ALI
I HAVE CHRYSLER 55HP TWO STROKE TWO CYL O/BOARD.IT WILL NOT START.I HAVE NO SPARK AT PLUGS AT ALL.I HAVE ALREADY CHECKED AND SET .015 GAP ON POINTS STILL NO HELP.DOES ANY BODY HAS ANY CLUE,I THINK IT IS POWER PACK.MAGNA POWER IGNITION.P/N. 9GCO.WHERE CAN I BUY THIS PART.I HAVE ALREADY CHECKED LOCAL SALVAGE PLACES NO HELP YET.HOW CAN I TEST COILS.IT HAS SEPRATE COIL FOR EACH PLUG.I WILL APPRECIATE ANY HELP.THANKS
JB
Re: CHRYSLER 55HP WILL NOT START .
Howdy, Jet. <br /><br />Your post would be a lot easier to read if it was not all caps.<br /><br />When spark goes out on both cylinders on one of those old monsters, I am more likely to suspect a neutral start switch or a kill switch as the source. Have you checked them out?<br /><br />Do you have a manual? What year is your engine? Do you have one set of points or two?<br /><br />Let us know. :)
steelespike
Jetmd.When checking kill switch dont forget they are normally open to run closed to stop.<br />Napa has an electronic ignition conversion for<br />2 cylinder Chrysler/Force motors. Unfortunately<br />only for motors without charging circuits.<br /> Fairwinds marina at: www.fairwindsmarina.com<br />is a Chrysler/Force dealer maybe they have parts or can steer you in the right direction.<br /> Good luck.
