twocyclemania
- Aug 10, 2010
- 505
Was replacing the points on my 1978-79 Chrysler 6 hp and noticed that when rotating the crankshaft/cam the point (rub) is not always in contact with the cam. I was under the impression from working on other motors that the 'rub' was always in contact with the cam. Is this normal or am I doing something wrong. These are the correct and identical points that I removed. I have the gap set (020). I did notice that the cam has wear marks about an inch or so before and after top dead center; points may not be in contact with the cam on a continual basis.
