Chrysler 75 hp Distributor cap gasket?
ErSa
I wonder if the cap gasket (#14030) under the distributor cap has an important
funktion? Can something bad happen if I don`t use it?
What is the thickness of the gasket?
jerryjerry05
F14020-1 Can be found on Ebay from $7.25 to $30
Ebay # 173114838757 is the cheapest one.
But you can run without it.
It is a moisture seal and should be used.
tg3690
Ebay item #174010886289 $8.10 Free shipping. This is just the cork gasket, not the cap seal.
tg3690
I had to order one of those a few weeks ago.....when I found that my distributor cap didn't have one either.....although it had been running for years without one. Like Jerry said, it helps to keep moisture out. (y)
