Chrysler 75 hp fuel spitting out of carb
Ferretlauncher
I have a decent amount of fuel spitting out of my carbs any idea why? I know very little of outboard mechanics so use small words haha
mfkadz
I am guessing it will not start. And while cranking you have mix spraying out of the carb. That is the sign of a reed problem.
You will need to get at and inspect them. They should lay flat and not leak.
Mike
Frank Acampora
If you can see fuel spitting out, then you do not have the air box installed. These engines are reed valve engines. Because reeds do not close instantaneously and because there is a single carb for each cylinder, there is always a little fuel/oil mix blowing out the carbs. This is because of the reeds and the pulsing nature of the airflow. The air box collects this spit-back and recycles it through a fitting and tube on the bottom back into the manifold.
If you have fuel dripping from the airbox, then the fittings or hose are clogged.
