Hello and thanks for taking my question. I'm an auto mechanic but have never worked on a boat. We just bought a boat with a 75 HP Chrysler outboard on it with electronic ignition not sure of the year but I'm guessing late 70's. (If anyone knows what the year is that would be great) Model # 757B8D Ser# 1027. We have only had the boat out twice. The first time it didn't run too bad but it had a miss at higher rpm. The second time we took it out it would only go very slow. When you try to speed up it would quit completly. Then when you try to start the boat it cranked over fine but would not start while cranking, when you let go of the key and stopped cranking then it would start. This tells me there is not enough voltage to the ignition system while the starter is drawing current. The reason I know this is an igniton problem and not fuel, is when I got it home I put it in a barrel of water and did a spark test. I just inserted a wire into a spark plug boot so I could watch it spark to ground as the engine was running. Everything looks good at an idle, but as I reved the engine higher and higher the spark all of the sudden quits completely and the engine stops. I was telling you it won't start until you quit cranking, the funny thing is the first time you start the engine say in the morning, it starts normally while you are cranking. Then when I rev it up and it quits, then it goes into not starting until you let go of the key. (Very strange) The battery is brand new and shows 12.5 volts when the engine is off. While running the voltage is around 13.0. I show the same voltage at the ignition terminals inside the engine compartment so it's not bad cables or anything. I wondered if maybe the voltage was still too low so I hooked up jumper cables from my truck and then had voltages of 13.6 but when I run the boat engine it behaves exactly the same way. I talked to the boat shop that has worked on the boat before but they were not much help, they did say the CDI had been replace about three years ago part # 523301-1 and the Pre-amp module was replace last year. Any advice you could give would be very much appreciated. Thanks
