Chrysler 90hp will go full throttle in neutral but not when gear
LugnutMT
I just recently bought this boat and did some minor repairs..... impeller and new gear oil.. I can get it to go about 5 to 10 miles an hour but after that it boggs out and dies.. I should add that I am at high altitude bout 5500 ft.. I have read in some posts that if I sqeeze the primer bulb nothing changes when running. It seems to be timed right cause I can go full throttle in neutral
jerryjerry05
Full throttle with no load means nothing.
​Clean the carb.
Check the fuel pump diaphragm.
Do a compression and spark test.
