Re: Chrysler carb problem
Hi Roy,
Before you strip and rebuild the carbs and pump, I would check for an air leak (vacuum leak) between the carb and the reed valves. In my experience, an air leak fault will be "masked" by enriching the mixture by choking the intake. If you are sure you dont have an air leak, then by all means check and rebuild the carbs and pump.
