polkadots1
- Aug 27, 2010
- 5
Hi all
I?m wiring up my Chrysler control box for the first time, as was wondering if you could please tell me if I have everything wired to the correct places, before I hook up the battery and test. I don?t want to short anything or blow anything up?
I have a Chrysler magneto system (45hp - model #455HC)
It?s worth noting that with exception of the ?I terminal? all wires are in the same place they were on the old control box I replaced- and that worked OK. My main question is if I have the correct stuff hooked to that ?I terminal? ? before there was nothing hooked to it, and I want to have it so that the 12v dashboard accessories come on when the key is turned.
Also the tach and the overheat buzzer are new additions- the system didn?t have those before- so hoping I have those wired correctly.
Here?s how it?s wired now:
B Terminal - Red wire (battery)
C Terminal ? Green wire (choke)
S Terminal ? Yellow wire (start)
M Terminal ? Light Blue wire (ignition)
I terminal ? to 12 volt accessories/dashboard (and also to one lead from my overheat buzzer, other buzzer wire goes to my orange overheat sensor wire)
M terminal ? White wire (ignition/tach) (and also one wire from this going to my tach, other tach wire goes to ground)
Any input would be greatly appreciated. Thanks in advance for you help
best, Pat
best, Pat
