Chrysler / Force Starter
I have a 1976 Chrysler 55 hp and I’m trying to find an after market starter for it. Can someone help me out?
tommarvin
Ensign
Hey, your in the wrong section, but we had a force 125hp why do you think its the starter? Are you sure the batterys are fullly charged,are all the battery connections tight, starter motor connections tight, we had a fuse that would blow and you need to reset it.push button fuse. there was a neutral safety switch that would get out of adjustment,starter wouldnt work.
,there are huge starter motor companys on line, you need to remove your starter and know exactly what it looks like so you can find it by looks. You should start with a google search" starters" they will pop up.
jerryjerry05
Sometimes just taking it apart and cleaning it can make a huge difference??
Over the weekend I took my diesel 6.5L Turbo starter apart. It was dragging and making it had to start.
Cleaned/ greased and the difference is AMAZING!!
Most of the aftermarket starters are made in China.
CHEAP JUNK!!!
Be careful what/where you buy.
Maybe Franz Marine? Master Tech Marine
