Okay, I've posted on here a couple of times, and received some good information. Hopefully someone can help me with this because I'm getting a little confused now. '73, 85hp, Chrysler, magnapower ignition (1 coil, 1 set of points). I'm getting good spark all the way to the plugs, each wire will jump a 1/2" gap. The problem is the bottom cylinder isn't making power. When i shut it down and pull the plugs the bottom plug is very clean but is also very wet with fuel, no water bubbles at all. I've moved the plug wires around at the distributor cap and spark plugs and the problem stays on the bottom cylinder. I've checked the compression: 120,115,120. Could I be getting water in the bottom cylinder and not see bubbles on the plug or piston dome? If I had a leaking head gasket wouldn't my compression be down? If I'm somehow losing spark on that cylinder, could the fuel mixture cause the plug to look like new since it isn't getting burned? My thoughts now are new rotor and distributor cap, new exhaust plate gaskets, and new head gasket, but I don't want to throw money where it's not needed. All help will be greatly appreciated.
