Just bought a 1977 Chrysler 55hp Magnapower II and I apparently need to replace the ignition switch that came with it. There is no key, it won't shut the motor off after it's started either and unless it's turned off after starting only 1 cylinder fires. I didn't wire it, it's the way it came so it may be mis-wired also.
I need push to choke and there is a sticker on the block that says to wire it the same as a magneto ignition. I notice that there's no white wire, the schematics I've seen use it as an ignition ground, maybe this is why it wouldn't shut the engine off??
