Chrysler. ?Install a cheap, plastic, disposable fuel filter BETWEEN fuel pump/carbs"
Chrysler. ?Install a cheap, plastic, disposable fuel filter BETWEEN the fuel pump and carbs, do not depend on the strainer on the fuel pump.?
1. Are filters between the fuel pump and carb ?mainly? to catch parts of a bad diaphragm, trash from the tank, both? My disposable filter has always been between the tank and fuel pump. It verify the flow of fuel to the fuel pump if needed w/o pulling the cover to see the bowl. I possibly need 2 filters.
2. Is the attached stretched fuel pump?s diaphragm a good example of one that ?will cause problems or not necessarily?? This is one that was posted vs mine.
JOW
JOW
