Re: chrysler model number 1159h8b ignition switch diagram
Good evening everyone, I hope someone can help me.
I have just bought an old Chrysler 30hp 2 stroke electric start which also has a pull cord, although someone has taken it off!
i don?t know how old the engine is, but i?m guessing 70?s.
On the engine plate it says model number ? 307111D, and serial number ? 1173.
Can anyone tell me how old the engine is?
Also i have a wiring problem, someone has replaced the wiring with caravan wire black cable,although there are white, yellow, green, red, blue and a black cable, also a brown, I managed to connect it up to the ignition switch and I can start the engine, but can?t turn it off as it carries on running, the only way I can stop the engine is by pushing the key inwards which seems to activate the butterfly flap on the carb and closes it which does stop the engine, I assume this isn?t correct?
The ignition switch does seem to be a bit past it, as you can use it without putting the key in, but I have tested it and it seems to be ok, I can?t find any sort of kill switch, and does this engine have battery charging or not?
Even with the engine stopped, if I push the key inwards it makes the butterfly flap close?
sorry for all the questions, been scratching my head all day, and it now hurts!
I need help people.
Thanks
Mike
