Chrysler not shifting forward
7lazy77
My 75 hp Chrysler will not shift forward & grinds as if it is trying to get in gear. Reverse works fine. What is the problem? Thanks
tater76
Re: Chrysler not shifting forward
Sounds like a linkage problem on the shift cable side. unhook the cables shift it manually, if it shifts into forward ok manually, then adjust the cable end until it works as it should.
jerryjerry05
If it's grinding going into gear.The clutch dog is probably wearing down and needs to be replaced.After you do what tater says look at the dog.
Fortunatly the lower is fairly easy to take apart.J
7lazy77
Thanks for the help, let me see what I find out.
