Hi All,
Greetings from the land of 10,000 lakes. I hope someone might be able to offer some suggestions about possibly things I’ve overlooked in trying to solve an issue with my 115hp Chrysler (motor # 1159H8B).
The Brief History:
Two months ago, distributor rotor broke off distributor shaft while at WOT. Motor killed instantly. Found distributor off a running Chrysler 105hp 4 cylinder. Swapped entire distributors with broken to running one.
Now motor runs, idles well, can do ¼ throttle, maybe up to ½ throttle.
WOT throttle from a dead stop results in motor hitting on all 4 for a short period, quickly fades (bogs), then wants to kill. All in about 20 yards or less. Motor stays running if you bring the throttle back.
Items I’ve checked:
-Upon reassembly, set timing according to instructions outlined by the “mweverett” youtube channel.
TDC is correct, motor is timed to 32 degrees, arch on distributor pulley lines with curve of flywheel at TDC.
-First time out after repair noticed bottom carb was leaking gas heavily. Have since pulled both carbs. Found each needle stuck in the “up” position where it was not resting on fuel bowl tab. Corrected that. Needles are still in good condition (new a couple seasons ago).
-Blew carbs out with cleaner & compressed air, set floats to 13/32”.
-Changed plugs to NGK BUH’s.
-Changed fuel line to clear so we could see gas pumping
-Replaced primer bulb to eliminate that as a cause
Important observations:
-Squeezing primer bulb when bogging does not appear to help this issue.
-Volume of gas being sucked into motor when throttle is at WOT does not change from idle/trolling speed
-Gas does not seem to be pulled consistently. Some gets pulled up, then theres a break. Some more, and then a break, etc….
Things other folks have said to evaluate:
-Boat uses two portable red tanks. Could click on connector be bad? Symptoms of a bad connector?
-Some have said rebuild fuel pump and/or fuel pump diaphragm? If that was bad wouldn’t squeezing ball have noticeable impact?
Just baffling, seems like air is getting into the system and starving the engine. Motor ran fine at WOT prior to this distributor issue happening. Ever since, can’t seem to get it figured out.
Any additional guidance or suggestions is greatly appreciated.
Thanks,
Ryan
The Brief History:
Items I’ve checked:
Thanks,
Ryan
