Adam_c
- Sep 16, 2018
- 45
If I jiggle my 10 pin connector the engine stalls,
Obviously an issue in there, but would that cause my circuit break to "pop" thus not being able to start the boat? And would pushing the button reset it?
When it stalls when warm, It turns over but won't start, would that button make it start or could I have 2 issues the 10 pin connector and a possible bad coil!?
I just don't want to replace the coil if it could be this circuit breaker button.
Also how do I go about fixing the pin connector will the wire pull out from the pin so I can check it? Or do I cut the connector open?
Thanks in advance
Thanks in advance
