Sandpiper889xl
- Jun 4, 2020
- 6
I just replaced my 55 amp alternator with an identically spec’d one one my 83 SeaSprite (3.0 Mercruiser) and something weird is happening... It’s not charging my battery (12.3 v while off as well as while running). I checked all the connections and wires and have noticed nothing wrong or missing or broken, but this one oddity occurs: when I hit the red 50 amp circuit Breaker button while running and getting 12.3 v (at the battery and back of alternator), the rpms suddenly drop like it wants to bog down and stall, but then my multimeter reads 13.5-14 volts ( like it should be) for about 20-30 seconds, then the circuit breaker seems to trip or something again and my rpms shoot back up and the voltage drops back down to 12.3 v or so again.
I can’t find anything shorting or grounding, and everything is hooked up properly as far as I can tell.
Is my circuit breaker going bad? Should I put a 60 amp one in instead of 50 in case the new alternator is more efficient than the old one (even though is a direct replacement from DB Electrical)?
Any ideas or help is greatly appreciated.
