thephoneman
- Apr 24, 2009
- 75
Hey guys I'm back again. So a few weeks ago I had a knocking sound in my transom. Changed the u joints and reassembled. Next time on the water the noise was worse and ended with the u joint failing catastrophicly. After getting the parts I put in a new gimbal bearing (used the tool to align) new bellows kit etc, refilled the drive and got it back together. Upon testing it with the muffs on the out drive seems to be making a lot of clacking regardless of gear or neutral. It's hard to pinpoint it with the noise from the exhaust there as well and I haven't put it in the water to see if there original issue was fixed. So any suggestions on where to start? Thanks again for all the wonderful advice.
