Tafflad
- Oct 23, 2007
- 544
I need to clamp some 1.25" square tube onto the 4" x 2" trailer longitudinal beams. (to add guide-ons)
If I just use a single U bolt, this would be diagonal across both items, ... is that enough ... or is the Guide-on upright likely to twist if nudged ?
I thought about fitting 2 U bolts in a crossover 'X' ... but this would have top U bolt simply clamping down on the first U bolt ... it would not have good contact with the 1.25" tube ?
Is there a better way ... don't want to drill or weld as it would spoil Galv, and trailer takes salt water bath every weekend
