CLANTON: Chrysler question for Clanton
speed29668
For Clanton and all who can shed some light on this,<br /><br />Thanks for reading this postI have a 1974 75 HP Chrysler. When torquing the original pinion nut to 85 ft-lbs the drive shaft is very tight. I have not installed the lower gear case housing yet. The two bearings on the drive shaft alone are what I am refering to. I can barely rotate it by hand. When first loosening the nut it was not as tight as 85 ft-lbs. Is there something I am doing wrong? I read your other post on this topic. What is the correct way to check the shimming? <br /><br />Thanks for reading.
steelespike
Re: CLANTON: Chrysler question for Clanton
My manual only goes to 73 and only lists a 75 up to 68.But maybe 75 started up again in 74.My <br />manual says it uses a castle nut on the drive shaft and says finger tight then back off to allow cotter pin to be inserted.<br /> Book says late models use three studs and a seal ring.Earlier models use 2 studs and a gasket.<br /> May not be much help.<br /> Good luck
speed29668
Thanks for the reply. The lower unit on this is different from earlier models. I appreciate it though.
clanton
I just got home, will check book tomorrow.
clanton
The manual I have is not clear on the shimming or the pinion nut torque. I would look for a factory manual. Sorry cant help.
