cleaned the carb 5 times in as many days 115 still dies when put into gear
fishtricker
Re: cleaned the carb 5 times in as many days 115 still dies when put into gear
not really the kind of help i need
wilde1j
Tell us exactly how you cleaned the carbs? Did you soak them? Remove core plugs?
bob johnson
whats the model number?
what is the compression in each cylinder?
have you check spark with a spark tester?
bob
fishtricker
took a small wire and ran it through the low speed orifaces removed seats needles plugs sprayed the hell outta everything carb cleaner i could see the carb cleaner passing through all the passage ways well there is more info in the other thread I started a couple threads down
