Cleaning grease and sand off prop shaft.
lrdchaos
Took the props off my bravo 3 to have them checked and smoothed out by a prop shop. The prop shaft has old grease with sand embedded on the prop shaft. What is the best way to clean this off? Carb cleaner? Just rags?
crazy charlie
Brakeclean should do the trick.Wipe off as much as possible with rags first.Depending on how much sand is in the splines ,you may want to consider sliding a screwdriver down each spline to make sure everything is out of the groove.Charlie
dingbat
Use a wire brush to remove compacted sand and grease.
Flush with WD, wipe down then apply a water proof grease to the shaft
ahicks
Then clean the wire brush with brake cleaner or whatever solvent you have handy!
Chris1956
The Purple Stuff cleaner is a very good degreaser. Also, paint thinner will work well. Pretty much any solvent you have laying around should work.
The good news is that the prop shaft is not fragile, so you can use most anything plus a wire brush (if necessary) to get her clean.
lrdchaos
Thank you. I didn’t know if the bravo 3 shaft was different.
