Cleaning livewells?
TexSkeeter150
Going to fish in some local fishing tournaments in the spring and want to clean out the live well. What should I use to do this that won't poison the fish? Any advice on general maintanence after I start using it? Thanks for you help and advice in advance.
crazy charlie
Re: Cleaning livewells?
Get a spray bottle and some bleach.Be ventilated and spray everywhere.Let it sit for at least 10 minutes and follow up with a fresh water rinse and then any good detergent like simple green with a good scrubbing and rinse again and then some lemon juice and you are done.Charlie I guess a lot depends on how dirty it is already.
roscoe
One or two drops of dish soap, 2 cups of hot water, and a green scrubbie should do it. Rinse with hot water.<br /><br />I don't like using bleach on plastics, as they absorb the bleach which can dry out some plastic and make it brittle. JMO.
crazy charlie
I agree Roscoe,but only if you dont rinse it.Bleach will not adversly affect plastic if you only leave it on for 5 minutes and make sure to rinse it.Some stains will only come out with bleach and some odors will not come out unless you use bleach.Charlie
Hasbeen
After they are good and clean, wax the inside with a good car wax! Makes cleaning them easier and I havnt had any fish complain! I suppose Ill catch h**l for that one!
