cleaning manifolds, risers etc.
ski_atomic
Hi guys, quick couple of questions...what is the best way to clean the exhaust components and to take off old gaskets.
tommays
Re: cleaning manifolds, risers etc.
<br /><br />You can get a gasket scraper at any auto parts store<br /><br />You want to put a rag in a hole like this manifold so the stuff does not get in the motor :( <br /><br />The KEY word is to scrape NOT gouge it can take some time ,i like to finish it off with some Scotch Brite Pads <br /><br />You want to get it clean BUT not remove metal<br /><br />tommays
ski_atomic
sounds good, thanks very much, ill try that. how about the inside of the manifolds (rust and crap)<br />Thanks again
bruceb58
Take the manifold off and flush it with water the best you can. Saying that, I still have been able to hear rust rattling around in them after doing that.
bruceb58
calwldlif
I have "hot tank" mine<br />with success.<br />Auto machine shop does<br />this to clean motors for rebuilds
ski_atomic
i took them off and put WD40, then power washed it and now they are swimming in a hot water with some dishwashing soap. is it good???
bigbrownbuku
Master Chief Petty Officer
best gasket scraper i ever owned and still use is the cheapest plastic handle 1" wood chisel.
rodbolt
I use the 3M pads on a drill. eats gaskets and does not damage metal. check the surface flatness of the gasket surfaces with a straight edge and feeler guage, the corners near the bolts tend to rise.
ski_atomic
Thanks everyone, i put the stuff back together and seems to be working now.
