cleaning sunbrella top
crazy charlie
I have a 2 year old navy top and I have the same black run streaks that you get on your hull after it rains on it.I have tried cleaning it with mild cleaner and some bleach with no effect at all.The color is gray and the light color shows everything.Anybody have any luck with this before???Charlie
shady8240
Re: cleaning sunbrella top
Charlie,<br /><br />I own an awning company and deal with Sunbrella on a daily basis. Great material although the grey is a bit tricky. If your really gung ho on getting it clean here is what you can do. Take it off the boat and make a solution of 1 cup of bleach to 2 gallons of water, and about a half a cup of ivory liquid soap. Soak it really well with a hose and scrub it with a medium bristle scrub brush. If that does not take the marks off then you can rinse it with a power washer. BE VERY CAREFUL as you can easily damage the Subrella by doing this. You must keep the nozzle about a foot away from the fabric or you will split the fibers. It sounds to me like the mill finishing is also gone so you will need to apply a top coat after it is clean and dry. You can use a variety of silicone based products found at your local auto parts store used for convertible tops. After all this is said and done, a simple rinsing after each trip should keep your top looking good. Advice, when you get a new top get a dark color, and if this does not work, it is not going to get clean. Good luck.<br /><br />Shady
crazy charlie
Thanks Shady I will give it a try,I have a small pressure washer.If the top was not only a year and a half old,I would change to a darker color but this is what the boat came with when I bought it .Charlie
