Re: CLeaning the Bilge
Sorry to hear about your mess.Usually I use dawn dishwashing liquid and it works great,but it sounds like you may have more of a job than it can handle.For a tougher job I use Simple green.I recently used some crap I saw at a dollar store called" Simply awesome ".And for 99cents it really was awesome,just make sure you use gloves,it is really strong.Try the cheap ones first,the simple green is medium priced and as a last resort you can get a heavy duty bilge cleaner in a marine store for about 8-10 bucks.The only thing about the bilge cleaner is that they are usually supposed to be left in the bilge as you ride the boat around,so they dont work as fast as the others.Use a high pressure nozzle on your hose when you are ready to drain the suds out of the bilge ,it will help remove the residue.Good luck. Charlie
