Clear coat spider crack repair
jedimaster
Hey, I have some spidercracks in my top cap and wanted to see if I can minimize the appearance of them. I was thinking of using a needle to open them up a bit and then using some sort of clear coat to fill it then wetsand and buff it after. Anyone ever tried this before? Any recommendations on what to use? I can't seem to search the forum anymore for whatever reason. This is a fiberglass boat with sparkl gelcoat and then a fairly thick clear coat. Not sure what material the coat is... Resin.. Gel??? no idea. Anyone know what they use on bass boats to do the clear coat part?
jedimaster
Also I should mention that the spider cracks are pretty minor and do not appear to have gone all the way through to the colored base. I can see in a few of them a little bubbling/separation between the colored part and clear coat part.
depends on manufacturer. some use clear paint, some use clear gel.
clear gel has minimal UV protection properties and has a finite life (about 20 years)
best bet....grind off the offending gel and either re-gel or repaint.
