Re: clear coat
Whoa! Before attempting to spray clear coat on your finish, I suggest finding some Penetrol at either your local West Marine or other marine supply store. One 12 ounce container will more than adequately provide you with a clean clear coat over your faded paint. However, Penetrol is not a permanent fix but a good interm resolution to a ugly problem. Otherwise you will have to sand, repaint, and then re-clear coat, and that will cost you. Try the Penetrol, I think you will be pleasantly surprised. Penetrol itself when dry is like a shellac (did I spell that right?), it is very thin, almost like paint thinner, so don't expect it to be thick like house paint, or even spray paint for that matter. Very light brush strokes carefully applied will produce no runs and a smooth shiney hard finish that will last.....A while.
