Cleaver prop
LubeDude
Can someone that knows props explain the advantages or disadvantages of Cleaver style props? Also, through hub and over hub configurations.
Re: Cleaver prop
LubeDude, You're asking a Question,<br />That Needs an Encyclopedia to Answer.............. :D <br />Well, The Short(Very) Story.........<br /><br />Cleavers are used in a Surfacing mode... The Solid, Straight Trailing Edge, helps keep it Hooked Up, While spinning in Air,+ water......<br /><br />Thru-Hub is what Most of the props you see are....<br />It gets the exhaust out of the way,+ Quiets it down......<br /><br />Over-Hub is used, in Some instances, for Helping it to Ventilate, at low speeds, Because it's pitch is too high....<br />Controlled Slipage.....<br />Then it Hooks Up,+ You FLY .............. ;)
LubeDude
Re: Cleaver prop
Im asking the question as I have a chance to get an over the hub four blade cleaver and Im wondering if I want to mess with it. It might be fun to have if Im just going to take to boat out and race around. Right now with a regular four blade Im throwing a roostertail you wouldnt beleive, (Looks like a jet boat), so I know Im running the prop pretty high. My water preasure is good so I thought I might try the over the hub cleaver. If I do not like it I guess I can always Ebay it.<br /><br />Thanks for your reply! Thats pretty much what I thought anyway.
Bass Runner
Re: Cleaver prop
if you are running the prop high now you are already ventilating the prop with the over the hub you will get even more slip WATCH YOUR RPM
