cleaver prop?
catfish1
whats the advantage or disadvantage of a cleaver prop?<br />the reason i'm asking is i saw one on ebay that will fit my motor, but i dont know anything about them.
sloopy
Re: cleaver prop?
You will be able to go faster, But forget about reverse.
catfish1
Re: cleaver prop?
so a cleaver prop is built for forward speed, right? but i wont be able to go fast in reverse? or, i wont be able to move in reverse at all?
sloopy
Re: cleaver prop?
you will be able to go in reverse but you will crawling to one side ten times more then normal. It will also take more throttle to get the same response in forward. What size and type is your boat? What hp; engine; propsize; cleaver prop size. <br /><br />By the way if you have a pontoon.... Don't waist your money on a cleaver.
catfish1
Re: cleaver prop?
the boat is 14ft, i have smart tabs on it now but the pic doesnt show it. the motor is a 50hp evinrude (small gearcase), i'm running a 11 3/4x17 michigan prop, the prop i'm looking at is 11x17 ss cleaver, teflon coated. i'd like to get a little more speed, but wouldnt we all :D i get 35mph now, i'm not too concerned with the reverse speed as long as i can reverse.<br /><br />
boat3.
Tabman II
Re: cleaver prop?
catfish1,<br /><br />Do you have any trouble reversing now with the Smart Tabs installed or not?<br /><br />Sincerely,<br />MJ Thomas<br />Bennett Marine, Inc.<br />Client Services<br />trimtabs@earthlink.net<br />www.bennetttrimtabs.com
Dhadley
Re: cleaver prop?
The basic idea of a cleaver is its a "stern" lifter. We use them a lot on air entrapment hulls where we arent concerned about gaining bow lift. A lot depends on the rake angle too. A true cleaver is a surfacing prop. IE -- to be most efficient the blade tips need to surface or come out of the water at the top of the revolution. Therefore a true cleaver is usually best run at an very high X dimension.<br /><br />Good luck!
Hooty
Re: cleaver prop?
Yeah, but what 'bout reverse? ;) <br /><br />c/6<br />Hooty
Dhadley
Re: cleaver prop?
Just hit the "Down" button of the hydraulic jackplate and itll be fine. Always worked for us.
Chinewalker
Re: cleaver prop?
DHadley's right about the surface piercing aspect. You're throwing your money away if you don't jack that puppy up. If you want to keep the prop submerged, stick with a round-ear through-hub prop...<br />- Scott
